Страница 1 из 1
email2sms приходит отчет об ошибке
СообщениеДобавлено: 29 ноя 2012, 16:56
malec
Пишу софтинку с кодом формирования темы сообщения:
.Subject = "malec" & " " & MaskedTextBox1.Text
Тобишь
Тема = "LOGIN" + "ПРОБЕЛ" + "номер телефона формата 79990001111"
В теле сообщения генерированный код.
Сообщение отправляется с почты с которой регистрировался.
На что мне приходит сообщение:
Dear user!
Your request to send SMS is not elaborated
The reason: Failed to authorize by email
The request should be made in the following way:
In subject of letter you should indicate:
your login
number or several numbers comma separated, up to 100 numbers. (It is not necessarily if you have attached file with telephone numbers)
time (in format HH:MM) or date and time of dispatch (DD.MM.YYYY HH:MM)
number of sender (in format ani= number of sender)
notification’s mode (if you would like to have notification, you should write the word silent in the subject of letter).
In case you did not attach file with numbers and message text to the letter, the contents of letter should not be empty because it is a text of your message
Sender number should consist of phone number up to 20 digits or text written by latin digits and not exceed 11 symbols. You may use such symbols as: (point), _ (underlining), - (). Sender number should be one of the following numbers: '79032208855, Comtube.com'. In case you indicated other sender number it would be used the number by default - 'Comtube.com'. If you want to use other sender number you should send request with such number to our contact center
This letter should be sent from e-mail address indicated on your page "My profile – My contacts" and authorized
If there is attached file, it should be simple text file. Also it would be better if this file will be in UTF-8 format. Otherwise it is possible the text message will be unreadable. The size of attached file should not exceed 1 Мb.
The quantity of numbers should not exceed 200, and quantity of tasks should be no more than 50 per day. If quantity of numbers is exceeded only 200 numbers will be elaborated and the rest of them will be ignored. If you would like to make more SMS bulk you should send request to our contact center and indicate quantity of numbers and quantity of tasks.
The variants of request for sending text messages:
You should indicate numbers in the subject of letter and message text in the contents of letter
You indicate numbers in attached file (not in the subject of letter) where each number is in separate slot. Message text should be indicated in the contents of letter
You do not indicate numbers in the subject of letter and the contents of letter is empty. In this case you should indicate numbers and message text in attached file
Format of numbers and message text:
You should indicate number and message text in each slot divided by semicolon. For example,
79161234567;Dear Vyacheslav! 79265678923;Dear Andrey!
Numbers and message text should be indicated in the following format:
---START SMS---
TO:
79031234567
79252345678
79163456789
BODY: Happy New Year!
---END SMS---
---START SMS---
TO: 79163456789
BODY: Dear Peter!
Give my money back!
---END SMS---
Before dispatch you should assure that you have enough money on your account for task performance. Otherwise it will be broken off. In order to continue sending you need to credit account and start sending manually.
Best regards, "Comtube".
Tel/fax: +7 (495) 961-00-08, SIP ID: 100000
E-mail: support@comtube.com
Re: email2sms приходит отчет об ошибке
СообщениеДобавлено: 29 ноя 2012, 17:12
malec
Проблема решена, не был разрешен для авторизации)))
СообщениеДобавлено: 29 ноя 2012, 19:29
malec писал(а):Проблема решена, не был разрешен для авторизации)))
Да, в письме и было так сказано: The reason: Failed to authorize by email.
Наверное, необходимо в описании ошибки добавить шаги по ее исправлению.
СообщениеДобавлено: 30 ноя 2012, 10:19
malec
Или писать её на языке основной категории пользователей.
СообщениеДобавлено: 30 ноя 2012, 10:52
malec писал(а):Или писать её на языке основной категории пользователей.
Так, насколько я помню, язык берется из настроек в личном кабинете пользователя. У вас на сайте русский или английский язык?
СообщениеДобавлено: 30 ноя 2012, 11:11
malec
Русский конечно
СообщениеДобавлено: 30 ноя 2012, 11:17
malec писал(а):Русский конечно
Хм, значит, есть где-то ошибка. Дело в том, что у меня то ответ приходит на русском. Где-то значит, не ладится. Ок, поправим.
СообщениеДобавлено: 30 ноя 2012, 11:20
malec
Заранее спасибо!
