pnm писал(а):Все починился, все нормально работает на 1.4.26.2. Ставил 1.6.2.0-rc1, даже екстеншен зарегить не мог. Вот такой баг был https://issues.asterisk.org/view.php?id=15353
17:11:17.938 2 SIGNAL-000284 NODE-000054: REGISTER sip:Provider1.sipgw
17:11:17.938 2 SIGNAL-000284 REGISTER sip:Provider1.sipgw via sip:Provider1.sipgw
17:11:17.938 2 SIGNAL-000284 relaying to sip:comtube.ru via sip:provider1.sipgw
17:11:17.938 2 SIGNAL-000284 {1} sent to SIPC-000220: REGISTER sip:comtube.ru
17:11:17.938 2 SIPC-000220 REGISTER sip:comtube.ru
17:11:17.939 2 SIPDATA-002063 out: req [192.168.8.135]:5060 -> udp[62.117.120.98]:5060 REGISTER(414 bytes) sip:comtube.ru
17:11:17.939 2 SIPC-000220 [002063] REGISTER sip:comtube.ru sent [192.168.8.135]:5060 -> udp[62.117.120.98]:5060
17:11:17.941 2 SIPDATA-002064 inp: rsp [0.0.0.0]:5060 <- udp[62.117.120.98]:5060 401-REGISTER(465 bytes)
17:11:17.941 2 SIPDATA-002064 sent to SIPC-000220
17:11:17.941 2 SIPC-000220 [002064] 401-REGISTER received
17:11:17.942 2 SIGNAL-000284 401 received from SIPC-000220
17:11:17.942 2 SIGNAL-000284 401 relaying
17:11:17.942 2 SIGNAL-000284 releasing
17:14:10.047 2 SIPDATA-002103 inp: req [0.0.0.0]:5060 <- udp[192.168.40.112]:34700 INVITE(1101 bytes) sip:99365786@192.168.8.135;user=phone
17:14:10.047 2 SIPDATA-002103 created SIPS-000234
17:14:10.047 2 SIPS-000234 [002103] INVITE sip:99365786@192.168.8.135;user=phone from udp[192.168.40.112]:34700
17:14:10.047 2 SIPDATA-002104 out: rsp [0.0.0.0]:5060 -> udp[192.168.40.112]:34700 100-INVITE(332 bytes)
17:14:10.047 2 SIPS-000234 [002104] 100-INVITE(trying) sent [0.0.0.0]:5060 -> udp[192.168.40.112]:34700
17:14:10.047 2 SIPS-000234 created SIGNAL-000296
17:14:10.047 2 SIGNAL-000296 SIPS-000234: INVITE sip:99365786@192.168.8.135;user=phone
17:14:10.047 3 SIGNAL-000296 rejecting INVITE from postmaster@ufs.su w/o authentication
17:14:10.047 2 SIGNAL-000296 401 generated
17:14:10.047 2 SIGNAL-000296 401 relaying
17:14:10.048 2 SIGNAL-000296 releasing
17:14:10.048 2 SIPDATA-002105 out: rsp [0.0.0.0]:5060 -> udp[192.168.40.112]:34700 401-INVITE(477 bytes)
17:14:10.048 2 SIPS-000234 [002105] 401-INVITE(final) sent [0.0.0.0]:5060 -> udp[192.168.40.112]:34700
17:14:10.050 2 SIPDATA-002106 inp: req [0.0.0.0]:5060 <- udp[192.168.40.112]:34700 ACK(522 bytes) sip:99365786@192.168.8.135;user=phone
17:14:10.050 2 SIPDATA-002106 sent to SIPS-000234
17:14:10.050 2 SIPS-000234 [002106] confirmed: ACK received
17:14:10.051 2 SIPDATA-002107 inp: req [0.0.0.0]:5060 <- udp[192.168.40.112]:34700 INVITE(1369 bytes) sip:99365786@192.168.8.135;user=phone
17:14:10.051 2 SIPDATA-002107 created SIPS-000236
17:14:10.051 2 SIPS-000236 [002107] INVITE sip:99365786@192.168.8.135;user=phone from udp[192.168.40.112]:34700
17:14:10.062 2 SIPDATA-002108 out: rsp [0.0.0.0]:5060 -> udp[192.168.40.112]:34700 100-INVITE(332 bytes)
17:14:10.062 2 SIPS-000236 [002108] 100-INVITE(trying) sent [0.0.0.0]:5060 -> udp[192.168.40.112]:34700
17:14:10.062 2 SIPS-000236 created SIGNAL-000298
17:14:10.062 2 SIGNAL-000298 SIPS-000236: INVITE sip:99365786@192.168.8.135;user=phone
17:14:10.066 2 DIALOG-000042 created(authOut)
17:14:10.066 2 DIALOG-000042 caller set: postmaster@ufs.su
17:14:10.066 2 SIGNAL-000298 INVITE sip:99365786@192.168.8.135;user=phone via sip:99365786@192.168.8.135;user=phone
17:14:10.066 2 SIGNAL-000298 relaying to sip:9365786@comtube.ru;user=phone via sip:provider1.sipgw;user=phone
17:14:10.066 2 SIGNAL-000298 {1} sent to SIPC-000232: INVITE sip:9365786@comtube.ru;user=phone
17:14:10.067 2 SIPC-000232 INVITE sip:9365786@comtube.ru;user=phone
17:14:10.067 2 DIALOG-000043 created as DIALOG-000042 copy(copy)
17:14:10.067 2 DIALOG-000043 enqueued
17:14:10.067 2 SIPC-000232 created DIALOG-000043
17:14:10.067 2 SIPDATA-002109 out: req [192.168.8.135]:5060 -> udp[62.117.120.98]:5060 INVITE(1584 bytes) sip:9365786@comtube.ru;user=phone
17:14:10.067 2 SIPC-000232 [002109] INVITE sip:9365786@comtube.ru;user=phone sent [192.168.8.135]:5060 -> udp[62.117.120.98]:5060
17:14:12.000 3 SIPC-000232 calling timeout, resending
17:14:12.000 2 SIPDATA-002110 out: req [192.168.8.135]:5060 -> udp[62.117.120.98]:5060 INVITE(1584 bytes) sip:9365786@comtube.ru;user=phone
17:14:12.000 2 SIPC-000232 [002110] INVITE sip:9365786@comtube.ru;user=phone sent [192.168.8.135]:5060 -> udp[62.117.120.98]:5060
17:14:12.003 2 SIPDATA-002111 inp: rsp [0.0.0.0]:5060 <- udp[62.117.120.98]:5060 407-INVITE(596 bytes)
17:14:12.003 2 SIPDATA-002111 sent to SIPC-000232
17:14:12.003 2 SIPC-000232 [002111] 407-INVITE received
17:14:12.003 2 SIPC-000232 updated AUTH on 407-INVITE
17:14:12.003 2 SIPC-000232 sending ACK
17:14:12.003 2 SIGNAL-000298 407 received from SIPC-000232
17:14:12.003 2 SIGNAL-000298 updating DIALOG-000042 on 407-response
17:14:12.003 2 DIALOG-000042 signal expiration updated
17:14:12.003 2 SIPDATA-002112 out: req [192.168.8.135]:5060 -> udp[62.117.120.98]:5060 ACK(431 bytes) sip:9365786@comtube.ru;user=phone
17:14:12.003 2 SIPC-000232 [002112] ACK sip:9365786@comtube.ru;user=phone sent [192.168.8.135]:5060 -> udp[62.117.120.98]:5060
17:14:12.003 2 SIPC-000232 killing DIALOG-000043
17:14:12.003 2 DIALOG-000043 dequeued(kill)
17:14:12.003 2 DIALOG-000043 released
17:14:12.012 2 SIGNAL-000298 407 relaying
17:14:12.012 2 SIGNAL-000298 releasing
17:14:12.012 2 SIPDATA-002113 out: rsp [0.0.0.0]:5060 -> udp[192.168.40.112]:34700 407-INVITE(486 bytes)
17:14:12.012 2 SIPS-000236 [002113] 407-INVITE(final) sent [0.0.0.0]:5060 -> udp[192.168.40.112]:34700
17:14:12.015 2 SIPDATA-002114 inp: req [0.0.0.0]:5060 <- udp[192.168.40.112]:34700 ACK(819 bytes) sip:99365786@192.168.8.135;user=phone
17:14:12.015 2 SIPDATA-002114 sent to SIPS-000236
17:14:12.015 2 SIPS-000236 [002114] confirmed: ACK received
17:14:12.017 2 SIPDATA-002115 inp: req [0.0.0.0]:5060 <- udp[192.168.40.112]:34700 INVITE(1386 bytes) sip:99365786@192.168.8.135;user=phone
17:14:12.017 2 SIPDATA-002115 created SIPS-000238
17:14:12.017 2 SIPS-000238 [002115] INVITE sip:99365786@192.168.8.135;user=phone from udp[192.168.40.112]:34700
17:14:12.017 2 SIPDATA-002116 out: rsp [0.0.0.0]:5060 -> udp[192.168.40.112]:34700 100-INVITE(332 bytes)
17:14:12.017 2 SIPS-000238 [002116] 100-INVITE(trying) sent [0.0.0.0]:5060 -> udp[192.168.40.112]:34700
17:14:12.017 2 SIPS-000238 created SIGNAL-000300
17:14:12.017 2 SIGNAL-000300 SIPS-000238: INVITE sip:99365786@192.168.8.135;user=phone
17:14:12.017 3 SIGNAL-000300 rejecting INVITE from postmaster@ufs.su w/o authentication
17:14:12.017 2 SIGNAL-000300 401 generated
17:14:12.017 2 SIGNAL-000300 401 relaying
17:14:12.017 2 SIGNAL-000300 releasing
17:14:12.017 2 SIPDATA-002117 out: rsp [0.0.0.0]:5060 -> udp[192.168.40.112]:34700 401-INVITE(477 bytes)
17:14:12.017 2 SIPS-000238 [002117] 401-INVITE(final) sent [0.0.0.0]:5060 -> udp[192.168.40.112]:34700
17:14:12.020 2 SIPDATA-002118 inp: req [0.0.0.0]:5060 <- udp[192.168.40.112]:34700 ACK(807 bytes) sip:99365786@192.168.8.135;user=phone
17:14:12.020 2 SIPDATA-002118 sent to SIPS-000238
17:14:12.020 2 SIPS-000238 [002118] confirmed: ACK received
N:S:<(7d)@*> = +7495*@comtube.sipgw ;
ExtGateways = {comtube={AUTHCalls=Auth;Contact=allo@comtube.ru;DomainName=comtube.ru;Expire=30m;Password=*******;ProxyMode=Media;SubstContact=NO;SubstFromAddr=NO;SubstToAddr=NO;
UserName=209115@comtube.ru;Via="sip:209115@sip.comtube.ru:5065";};};
11:02:27.087 2 SIPDATA-000133 inp: rsp [0.0.0.0]:5060 <- udp[62.117.120.98]:5065 408-INVITE(475 bytes)
11:02:27.088 2 SIPDATA-000133 sent to SIPC-000010
11:02:27.088 2 SIPC-000010 [000133] 408-INVITE received
11:02:27.088 2 SIPC-000010 sending ACK
11:02:27.088 2 SIGNAL-000012 408 received from SIPC-000010
11:02:27.088 2 SIGNAL-000012 updating DIALOG-000001 on 408-response
11:02:27.088 2 DIALOG-000001 signal expiration updated
11:02:27.088 2 SIPDATA-000134 out: req [192.168.8.135]:5060 -> udp[62.117.120.98]:5065 ACK(434 bytes) sip:+74959365789@comtube.ru;user=phone
11:02:27.088 2 SIPC-000010 [000134] ACK sip:+74959365789@comtube.ru;user=phone sent [192.168.8.135]:5060 -> udp[62.117.120.98]:5065
11:02:27.088 2 SIPC-000010 killing DIALOG-000002
11:02:27.088 2 DIALOG-000002 dequeued(kill)
11:02:27.088 2 DIALOG-000002 MEDIAPROXY-000001 removing
11:02:27.088 2 ACCOUNT(postmaster) out call failed. Error Code=Client transaction timed out
11:02:27.097 2 SIGNAL-000012 408 relaying
11:02:27.097 2 SIGNAL-000012 releasing
11:02:27.097 2 SIPDATA-000135 out: rsp [0.0.0.0]:5060 -> udp[192.168.40.112]:34700 408-INVITE(378 bytes)
11:02:27.097 2 SIPS-000004 [000135] 408-INVITE(final) sent [0.0.0.0]:5060 -> udp[192.168.40.112]:34700
11:02:27.100 2 SIPDATA-000136 inp: req [0.0.0.0]:5060 <- udp[192.168.40.112]:34700 ACK(815 bytes) sip:9365789@192.168.8.135;user=phone
11:02:27.100 2 SIPDATA-000136 sent to SIPS-000004
11:02:27.100 2 SIPS-000004 [000136] confirmed: ACK received
11:02:27.488 2 MEDIAPROXY-000001 released
11:02:27.488 2 DIALOG-000002 released
11:02:27.488 2 UDPPROXY-000001 released. 0(0) <-> 0(0) sent in 32 seconds
11:02:27.488 2 UDPPROXY-000002 released. 0(0) <-> 0(0) sent in 32 seconds
11:02:46.396 2 SIPDATA-000141 inp: req [0.0.0.0]:5060 <- udp[192.168.40.151]:34700 REGISTER(831 bytes) sip:192.168.8.135
11:02:46.396 2 SIPDATA-000141 created SIPS-000006
11:02:46.396 2 SIPS-000006 [000141] REGISTER sip:192.168.8.135 from udp[192.168.40.151]:34700
11:02:46.396 2 SIPDATA-000142 out: rsp [0.0.0.0]:5060 -> udp[192.168.40.151]:34700 401-REGISTER(486 bytes)
11:02:46.396 2 SIPS-000006 [000142] 401-REGISTER(final) sent [0.0.0.0]:5060 -> udp[192.168.40.151]:34700
11:02:46.399 2 SIPDATA-000143 inp: req [0.0.0.0]:5060 <- udp[192.168.40.151]:34700 REGISTER(831 bytes) sip:192.168.8.135
11:02:46.399 2 SIPDATA-000143 created SIPS-000008
11:02:46.399 2 SIPS-000008 [000143] REGISTER sip:192.168.8.135 from udp[192.168.40.151]:34700
11:02:46.408 2 SIPS-000008 created SIGNAL-000014
11:02:46.408 2 SIGNAL-000014 SIPS-000008: REGISTER sip:192.168.8.135
11:02:46.408 2 SIGNAL-000014 REGISTER sip:192.168.8.135 via sip:192.168.8.135
11:02:46.414 2 SIGNAL-000014 200 relaying
11:02:46.414 2 SIGNAL-000014 releasing
11:02:46.414 2 SIPDATA-000144 out: rsp [0.0.0.0]:5060 -> udp[192.168.40.151]:34700 200-REGISTER(600 bytes)
11:02:46.414 2 SIPS-000008 [000144] 200-REGISTER(final) sent [0.0.0.0]:5060 -> udp[192.168.40.151]:34700
11:02:59.004 2 DIALOG-000001 released
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 68
